glue advice
has anyone found a really good glue to stick new vinyl in a z (replacing tweed) i used a spray adhesive and i noticed some of the panels are coming unstuck when the weather warmed up any advice any one cheers kev
I used contact adhesive and it worked a treat - can find out the exact one if you want as I still have the tin.
if u could bud mine is contact adhesive but as soon as it get a little warm it's starting to peel
yes mate spray adhesive is only good for up to 50'c or so and the car will get hotter than that - caravans use a hot melt system but i guess that is out of the question for most people - most contact adhesives would probably not be too clever either but you can get high temp ones which go to 120'c or so which should do the trick
Regards,
alex
when i was working at a joiners when i was a nipper we used an industrial strength contact adhesive to fix laminate, find that stuff and it would never come off :D
CJ, what did SE use to stick your rear lights on? pritt stick i heard :D
Evo-Stik Impact - Instant Contact Adhesive.
Comes in a big red and silver tin. You have to brush it on. Make sure its the Solvent one you get, and not the crap non-solvent one. B&Q Sell it, You'll probably have to take empty can to the Desk so they can get the real stuff out of their mini-safes.
It should be Thick Golden Brown.
i've just found some 3m 90 spray adhesive on e bay goes from temps -30 to 160 degrees c so hopefully this will do the job and a bargain at £3.50 a can rrp is anywhere between £7.99 and £12.49 a can
dont waste your money
get evo-impact
only the best materials mate - you could do it yourself with a couple of used washnig up bottles and some sticky back plastic :smash: :cool:
Regards,
alex
evo stick impact is what i used, after trying loads of others from b&q, very strong stuff but in the summer u WILL get the bubbles
