had a bitch of a day,fitted a sgp pulley an encountered problems on the way
1/the ajuster nut on the alternator rounded of so to get to it comfortably i removed the alternator took 1-30 mins to replace due to the fact refitting of alternator from engine bay is almost impossible,did it in the end replaced new belt job done
2/new problem the a/c idler pulley wont come loose the 14mm nut has completly rounded off WTF need to remove it to set the tension!!
so anyone know what i can do other than beat it,cut it off!
been along day :smash:
thanks vijay,il try tommorow :duffer:
although i was thinking of using my dremmel to cut the nut in half
do you think those wrenches are available locally as i need to this tommorow,any thoughts on nut splitters
cheers greg
try hitting a 13 mm socket on to it, it should bite into the nut and undo
i was trying that only prob the amount of room to swing a hammer is limited
just a thought greg
have you got one of those gator wrenches (think thats what they call them)
its like a socket with loads of pins inside it, which tightens up on rounded off nuts, as you turn it
just a thought greg
Good idea...the Gator Grip is great for botched nuts :eek:
If u cant do it then i would scrap it as its only a red Z bud :nelson:
Failing that weld summin onto it and crack it of...the heat would probably help to....but no turning back once u weld...unless u can get an angle grinder in their...Power Tools...luv em
Bit of this :smash: bit of that :smash: sorted :hyper:
Drill?? :D
Seriously mate,have you got a long thin chisel?-that'll do it! I have a set of 6''
stilsons for just such jobs-worth investing in mate! ;)
B&Q do them :) can you not get mole grips on it?
Vijay
Vijay
i could but it means removing the new sgp crank pulley,as i have limited left-right movement :headvswal
il try in the morning,if not im off to b&q thanks again vijay
all sorted used a turbomaster socket which has a spiral effect cutter inside-worked a treat and is a must for any DIY zeder :hyper:
