fuses
which fuse do i take out do depressurise fuel lines cheers
Its the Bright green fuel relay in the drivers kickwell.
Instructions
Remove the driver's kickpanel 2 screws are in the side of the panel, 2 are in the firewall, the last one is under the carpet by the dead pedal (5 x phillips).
Remove the first two screws of the door jamb's plastic trim (2 x phillips).
The kickpanel interlocks with the front edge of the door jamb trim.
Disconnect the fuel pump relay (bright green).
Theres an easier one in small fuse box infront of brake servo, saves removing any panels and getting on yer hands an knees :)
smithy
