Putting the pressure on her
Has anyone got a picture or can point me in the right direction of how to pressurise the intake system. I have got a leak somewhere I think which is giving me an irratict tick over & stalling problem. I'v heard there is an easy way of checking this. Any advice would be greatfully received ;)
About 2 years ago Vijay got some things made up to just do this job. You put his "boost leak detector" on the Y intake hose and pump air in.
Listen for leaks.
Locate leaks
Fix leaks.
Simple :D
There are quite a lot of people who need these so maybe its Vijay could be persuaded to get some more made up if there are enough who want them.
Listen for leaks.
Locate leaks
Fix leaks.
Simple :D
Thanks fella. I had heard of Vijay's leak detector but was hoping to sort it out tomorrow before the Zed meet at Ironbridge on Sunday. ;)
The only way to do it is to make your own leak detector.
I did it with 2 bake bean cans, a car valve and lost of gaffer tape. Wasnt that good though.
:ttiwwop:
so any one got any piccys of these thingys please?
Listen for leaks.
Locate leaks
Fix leaks.
Simple :D
Can I not just take the induction kit off, block the end somehow & pump air into it thruogh that?
If not what is the Y intake hose?
Yep, thats what a Boost leak detector does, you need a decent seal.
The Y-intake is the Y-shaped pipe where the Induction kit bolts up to.
:hyper: Thanks mate. Off to B&Q then :rofl: :rofl:
