Both headlights packed up ! help please
On sunday while going over a f***ing speed hump both my head lights flicked off then back on again, last night they both packed up, nothing at all. Is there a fuse for BOTH headlights or are they seperate ?, if one bulb goes, does the other not work either.
And can some one please point me to the jap - uk head light upgrade please
Cheers guys
hi paul both headlights are wired seperate they have fuses in the box just behind the pass side headlight they also have 1 relay each plus a main dip beam relay my gues would be you have a loose wire somewhere
Sounds like a loose connection some where or you have blown both bulbs :( which is not that hard to do.
Like has been said check all fuse connections and relays in the fuse box and on the back of the lights.
Just done some checks, both L and R fuses are ok, both L and R relays are 'clicking' on/off with headlight switch and the dimmer relay is 'clicking' on/off and high/flash beams are coming on with stalk/indicator switch. The only thing I can think it is, is a dodgy ground from the dimmer relay for the dim/normal headlight circuit, would any of you guys agree ?
I need to get the relay box out and check connections but there is a b1tch bolt to get to !
Give this a go.
Check wires to the back of the dipped beam bulbs. Mine kept on flashing on and off so I just secured and insulated them and no more flashing.
Give this a go.
Had the same more or less,drivers side connector had come off,bitch to get back on.
Tony
