  1. Tap the 3-dot menu (ā‹®) in the top-right corner of the browser.
doors on SWB & 2+2 are they the same?
are the doors the same on a SWB and a 2+2?
Ā
for an interior trim kit
Ā
cheers
They should be fella, as its only really the rear end that is different IMHO.
cheers Sgt
Ā
thats what i was hoping
Ā
see you on the 20th
Paul
you can compare against mine next Sunday at PPS if that's any help or I could go out and do some measuring
Phil
No.. the doors are definatly not exactly the same, the length is the same, but the rear upright section at the back going up to the targa is different, also the glass is shaped differently where it meet the targa or fixed top whetever is fitted.
Ā
If you cut the back upright section of the swb door it can be welded back to the 2+2 door and swap the glass, the original cut and weld section is clear to see which any good body shop could deal with, swb doors are in very short ( excuse the pun ) supply consequently have had to used this method in the past.
Ā
Jeff TT
trim for the door card is what i'm after, may have bought SWB instead of 2+2
so just checking
Ā
thanks everyone
From memory yes door card is the same.
Ā
Jeff TT
