Ok,just got back from a mates house,he has this problem,turn on pc,it gets to the windows load up screen,then goes blue,been in the Bios ,cant find anything untoward etc,error message reads,
Unmountable_Boot_Volume
Technical Info
Stop:0x000000ED(0X817A9E30,0XC000032,0X00000000,0X00000000)
have tried changing monitor,maybe its a graphic card prob,or HHD gone bad,any help appreciated,cheers,Tony :(
Technical Info
I used to get this on my old PC when I upgraded to XP. To recitfy it I had to boot from an XP CD and run CHKDSK on it or add the harddrive to another PC and run CHKDSK. Sorry, its all a bit vague but its a good while ago now. Diffinately a disk type problem though. In my case the problem was sorted by updating the firmware on my drive controller and it never happened again.
David
aye it deffo sounds like a hard disk problem - maybe some sectors have gone bad (quite rare tho - but hence the CHKDSK as David suggested). Has your mate installed anything recently (s/ware)?
We get this at work alot (tech support call centre), and as the chaps here are saying, chkdsk /r should sort it, followed by getting windows updates to stop it happening again (HDD firmware might sort too, it's something to do with disk write speeds, I think).
Not likely to be a hardware problem though :)
he installed Spy Watcher,but he allready had it on for a few weeks,he then says that last week he purchased the full version online from them,and updated it,thanks to all for info,will try and check out ideas next coulpe days,
Cheers,Tony :)
