despersately need help with escort
girlfriends car wouldnt start thought it were starter motor.put new starter motor :headvswal :headvswal :headvswal on and found out factory fitted imoboliser will not disengage.does anyone know how to disconect it or how to bypass it. its a 1994 diesel escort
thanks
Run a wire from the back of the Ign Switch from the starter terminal to the starters solonoid.
Job done.
Scubie, give me a bell tomorrow i`ll talk you through it. Common fault with Fords is the switch in the door that activates the factory alarm (£14.00 from fords)
Bob 08005422875
thanks lads. bob i'll def ring you tomoz morn. mtl i'll try that to put her on till can get it sorted properly. n greg belive me it came fooking close to that earlier.
thanks again
graeme.
