gauges
can some1 please tell me the best place 2 plumb the gauges in got oil pressure ( i know this 1 got the sandwhich switch) boost, water temp does this go on the top rad hose? also all the elect connections cheers. ;)
water temp does go in to the top water pipe,idealy you want to get smithys hardpipe and get him to weld your sender in much more accurate which you want with something important like water temp
wires are straight forward
water temp live=red black=ground blue=water sender
Oil - did you get a sender unit with it? if so they will usually replace the OEM nissan one on the sump at the back.
Water - Like's been said top rad hose. If you want to replace the top hose then try smithy or give getgreddy a call as he supplys a nice crome unit that fits between the two cut bits of hose.
Boost - On the left hand side of the balance bar theres a small pipe that comes from the back, t- piece it off and use that.
Electrical wise you can take any Neg and pos, i took mine from the ecu.
Kirbz
