Rear sub install
wheres best to run all the wires?
1) from battery to amp
2) from stereo to amp in the rear
I ran my Amp power cable through the bulkhead via the Bonnet release lever hole, down the sill and under rear seat to the boot.
and the RCA Cables from stereo to amp thru the centre console, under carpet, under seat and into boot.
theres a hole in the passenger side inner wing , i ran my power cable from the battery, through the hole in the wing and back into the car near the ecu , easiest way i found mate .
the rca leads run under the sills v easy to do.
I did the Exact same....easiest way i found.....! :D
