Upper LinkArms
Hi Pop-pickers,
Asked for some advice the other day on the resolution of a camber angle problem on my 300. And was kindly replied to by Legarth and Gio as to a few options. One from Z Centre and the other from Courtesy in the US.
Just wondering if anyone has used these parts and could give me some sort of recommendation, or not as the case may be on how well they have performed once fitted?
Cheers.
i got mine from CZP
will be fitting them this weekend, but they are serious works of art! amazing quality with bearings replacing the bushes :)
Hi Pop-pickers,
Cheers.
Thanx...haven't seen those ones. Let me know how you get on! :-)
Wasnt there some piccys of similar shape arms all bent to bu99ery from a site down under? they were maybe pretty anodised colours instead of all shiny but certainly that shape
yeah, there were some that made them from aluminium instead of stainless :x:
Paul what price did you get them to your door for? that's if you dont mind me asking
Cheers Gary
Cheers Gary
dunno really - i ordered them along with a whole load of other stuff :confused:
I got mine from Courtesy as well, the same 'Midori' style steel plated ones you see above. They are indeed a work of art! Easy to fit, and I couldn't believe the state of the bushes on the Stillen ones I removed... So bent I had to cut the bolt out to get it off the mounting bracket. Personally I would only fit them with solid (adjustable) front tension rods though. If you are going to fit solid upper links then you don't want compliance in the lower assembly. I bought the two together from Courtesy. Have a look here:- http://www.courtesyparts.com/z32/index.html
They have a special price on the upper links at the moment. However I am sure someone on here can get you the same ones over here. Just make sure the ones you get are specific to the 300, as there is a similar upper-link which doesn't have the offset on one side for clearance, and it can neck out on the mounting bracket under extreme bump.
