damn CoolWebSearch
this piece of adware got me last night! what a pain in the arse :mad:
Installed SpyBot and Adaware in the end (I know, I should have had these running anyway to block it), but they still couldn't completely remove it.
As soon as I fired up IE it would try to put itself back.
In the end I found something called CWShredder. This is specifically designed to remove it, so if anyone has the same problem, just donwlaod that straight away then install Spybot afterwards :cool:
I have a problem with this on my work computer. damn right it is a PITA!!! Have you got an address for CWShredder dude?
spysweeper from http://www.webroot.com will take care of coolwebsearch too
Guys you can kill it manualy
Peice of P iss.
Thoes things install a directory that is hidden, if you look at the Adaware search list and clickon more info for the problem it will give you the directory string. i.e
C/program files/heap of poo/lump up junk.exe
copy the lump of junk.exe file into search and delete it. then manualy delete the folder the same way.
then goto regedit and do the same.
job done
oh and reputable sites dont have this crap on there. you get it from visiting porn sites.....
tut tut tut :)
tut tut tut :)
So why did you have to delete it then :D
Pornboy :xxx:
try this site.........http://www.wickedweasel.com
not dodgy, but some fine women pics !
