plenum water by pass Q
what size water hoses and how much will I need to do the throttle body by-pass?
to do the water bypass you will need 8mil internal dia hose I would also not use Vac tube as it will not hold water with high temps
Ryan
8mm? Where are you bypassing them?
I did mine from under the back of the plenum, straight onto the turbo feeds.
Definately 6mm fitted there. Silicone hose is OK -20 --> 180°C roughly so should be fine. No leaks from mine anyway.
well you learn something new every day :hyper: :D , in the ones i have done i have always used 8 mil water hose as i did not think silicone would be up to the job , would certainly make life easier to use silicon hosing though
  • 1 month later...
Have you done this then Jaffa?
Out of interest, has anyone else done this with silicone hoses and had (or not had!) problems?
sorry for my ignorance
but why do you do this
less pipes to leak under the plenum, and consensus is that there is no point heating up the TBs.
ok thanks Mike
anyone got any pics or write ups on what hoses can be junked/bypassed
mind you the write ups need to be Deve8UK proof. (thats idiot proof)
as im still trying to find the greenish rightangles bit that is sticking my throttle open.
want me to pop over mate?
If that was the case then Smithy would have had to pay six million quid in compensation as he uses it for his rad kits :eek:
hold arm out and ill bite it off.
mind you I work in teh evenings at teh club. but that only in rochford.
