Stereo issues
Any ideas? Just been to get in the car and put the sounds on, but there seems to be no power at all to the headunit, the power arial doesn't go up, no power to the amp... nothing. It worked fine 2 hours ago... I've checked all the fuses I can see, but no problems there? Where is the fuse for the stereo normally? I couldn't see it labelled on the fuse holder cap? Any help would be appreciated cheers
is your amp getting power? it should have an inline fuse on the live feed from the battery to the amp. i take it it is aftermarket also, could be loose wiring somewhere at back of headunit, and make sure you press the on button ;)
Heh, yeah thanks for that ;)
ย
Turns out all it needed was a bit of hot air on the connector on the fascia plate to the head unit itself. Must've just been too cold... very odd. ?!?!?
ย
Ah well, it works now thanks :)
Yeah, these Zeds do get quite a bit of condensation eh?
