Heater prob
Nothing major this one but since ive put the dash back in my heater (no matter what temp its on) permanently blows hot air !!
Even if you notch it down to 10 degrees ! Now either i have a disease or houston has a problem !
Any ideas on this one gents ?
Three possabilities
1) First the operating cable to the heater matrix valve has broken
2) The outer casing clip for the above cable has come off
3) MOST LIKELY When refitting the two black ducting pipes under the knee pad area (drivers side) the cables to the two sensor ducts are not connected, this will always default to heater on if these are not connected.
Hope that helps
Jeff TT
thanks Jeff - would it have anything to do with two strange white plastic discs with a wire coming from them behined the stereo area ?
One was (as i say) behined the stereo so we put it back there, but we didnt know where to other one went so thats behined the stereo too ! This is the only thing playing on my mind after putting the dash back it - it may be entirely coincidental ?!?!?!
