Mind bender dials???
I brought some blue glow dials from america and i need some help/advice on how to sort the calibration.
I've got a import Z32 NA, They look like the right ones ( one dial hasnt got boost cut out)
My query is this........ My car has normal jap clocks with 190 kph max speed but has a converter on it so it now reads the kph in mph (still with original clocks, needles etc). My new dials have 160 mph and something like 220/240 kph on them. If i change the dials straight over will the speedo be correct or shall i take the conversion off??? I've compared the 2 speedo's next to each other and all 3 readings dont match.
Anyone got any ideas???
:confused: :headvswal :confused:
Cheers.
Dont suppesoed you anyone knows how to take the needles off without damaging them. I've heard if you just pull them off :), then you damage the spline and break the clock?????
you shouldn't need to take them off, and i wouldn't try. you can slip the dial fronts over the needle
