Splicing in new injector / ignition connectors
Hi! I am trying to trace a dodgy idle, and having started to do the throttle bodies, which were so clean it looked like they'd been done yesterday, I started on cleaning all the connectors. Then I stopped for fear of them falling appart in my hands!
So I am going to get new harneses from Courtesy for the ignition coils and the injectors. :dance: Do they both need splicing in? Or just the ignition coil harness? Is it a nightmare job to splice them in? :(
Give DaveC (PetrolHeads NW, in the traders section) a shout, he keeps these instock.
I personally wouldn't use Courtesy Nissan, as it can work out quite expensive on the import duty, as they use UPS, and you will DEFO get charged the full rate. An other alternative would be Concept Z Performance who are also over in the states, but are very friendly towards import duty ;)
Ooppssss! Forgot to answer the question :D YES they will both require to be spliced. You might consider the ECU Temp sender plug aswell.
Thanks! I'll buy a new soldering iron then... No worries on the import duty, I travel to the US about 4 times a month and bring everything back bit by bit. As long as it's below £145 ish... ;-)
