had remote start alarm fitted, hicas n abs light on now
i just had a clifford alarm fitted now my hicas light is on as is my abs n when floorin the beast it sticks at 4000 rpm and doesn,t want to do much please please help is it because of alarm or somethin else :headvswal
Did you have the problems straight away after the alarm was fitted ? if so take it back to the fitter and tell him that these problems only started once the alarm had been fitted.
They may have picked up on a wrong feed or something.
What model is the clifford?
the model is a rs 2.1 the problems started within 30 mile of driven er , went out tonight and took of battery and put back on again started car lights where still on switched everything of in car couple secs later they went out , turned my steerin and it felt ok touched brake and hicas light came on again then went out again , just as a wee experiment not touchin anythin else i put the rear window on and light came on again seconds later abs light came on , let car idle for ah bit longer then shut it down , haven't been out to it again but i'm just about to go out right now
Take it back to them and get them to double check their work. It may or may not be their work but it is better to find out!!
thanks for your reply oneday, spook to the fitter he strongly thinks it was not the fittin , tryin to find out other causes if any before askin him back up to sunny edinburgh
