Thanks Steve-o
Fitted the dask kit today - looks rather fetching :)
Thanks again mate - well chuffed with it!
:dance: Lookin good :dance:
Cheers matey ;)
That does look nice, looks like you did a good job too matey was it a ****er to fit?
Cheers guys :)
Wasn't too bad actually, the hardest part was getting all the dirt off the surfaces before sticking the kit to them!
Had to trim down the strip above the stereo as it was about 15mm too long, but aside from that the fit was spot on.
Was the peice above the radio a little too long... mine was, if it's the same kit I just fitted. Also found that the bit to the right of the stearing wheel looks odd, think it should have a bit more on it's left side into the steering column?!
Next step is to get rid of that godawful tweed - time to put in that order in with Luke.
The bit to the left of the steering wheel did look like it could have done with going into the steering column a little more, but I can't see it when I'm driving, so it ain't going to bother me ;)
another problem i found was the ashtray bit as when fitted! the ashtray compartment wouldent open had to get the scalpel out :eek: :D
Yeah, I had the same prob, so I moved it over a bit, now it looks crocked!! :cry:
the only bit in mine i couldnt fit was the cover for the auto P DN21 etc...really would have finished it off but when you put it over the thing sits too low
also the bit up the top where the heat comes out..not a particularly good idea putting it there, cos its silver it reflects on the window..not only that my trims been repaired there and you can see the flaws now..it draws attention to it...doh!
I thought it might not open properly once fitted, so I was particularly careful on that bit and it opens / closes fine - can't do long journeys without a cigarette!
I've yet to fix mine, so didn't put the trim on there, after seeing how the driver / passenger side vents reflect in the windscreen, I'm glad I didn't put the long trim-strips on.
Nice job! Looks like your handbrake needs adjusting though ;) (mine's the same)
