Well a rather annoying twist in the tale. Installed the crank the other day after completing all pre assembly prep. Everything seemed ok bar a slight bit of clearancing needed on the girdle plate. Took everything off and found a whopper of a scratch on one of my main bearings. Annoyed doesn’t come close!
I know the block and crank were crystal clean so I can only assume that my old pot of assembly lube had become contaminated with a bit of grit or who knows what. What are the odds?!?
So, yet again, a thorough clean of block and crank before sealing away on clean bags while I await new bearings to arrive….. and a NEW bottle of assembly lube by @torcousa via @nimbusmotorsport
By
nickz32 ·
Do not break the chain something terrible could happen to you, This
is a decent chain letter as opposed to normal chain letters/pyramid
schemes, this one costs nothing, and you can only win. Simply send
this e-mail to 9 of your mates.
INSTRUCTIONS.
Anaesthetize your wife or girlfriend, put her in a large carton,
don't forget some ventilation holes), and send it to the person who
is at the top of your list, Then cross that name off and add your
name to the bottom of the list. Soon, your name will be at the top
of the list, and you will receive 823,542 women through the post.
Statistically, among those women, will be at least:
0.5 Miss Worlds
2.5 Models
463 Wild nymphos
3,234 Good-looking nymphos
20,198 Who enjoy multiple orgasms
40,198 Bi-sexual women.
In total, that is 64,294 women who are simply hornier, less
inhibited, and tastier than the grumpy old bag you posted off. And,
best of all, your original package is guaranteed not to be one of
those that come back to you.
DO NOT BREAK THIS CHAIN LETTER.
One bloke for example who sent the letter to only 5 instead of 9 of
his friends got his original bird back, still in the old dressing
gown he sent her off in, with the same old migraine attack, and the
accusatorial expression on her face. On the same day, the
international supermodel he'd been living with since he sent off his
old girlfriend moved out to live with his best friend (to whom he
had not sent the chain letter)
While I am sending this letter, the bloke that is in 3rd place above
me has already received 837 women and is lying in hospital suffering
from exhaustion.
Outside his ward are 452 more packages.
YOU MUST BELIEVE THIS E-MAIL. This is a unique opportunity to
achieve a totally satisfying sex life. No expensive meals out, no
lengthy conversations about trivialities (that only interest women).
No obligations, no grumpy mother-in-law, and no unpleasant surprises
like marriage or engagement. Do not hesitate........send this letter
today to 9 of your best friends. PS. - Even when you have no
girlfriend, you can send your vacuum cleaner; one of the other women
that arrives will know how to use it.
PPS. - This letter can also be copied to women you know so that they can
prepare themselves for the great adventure that they may soon undertake
