heater
has anyone got any info on the air con/heater on a 92z, andys page only really covers 95. can't seen to get much heat out of it,is this normal are the heaters on import z's crap ?
Although the disagnostic on Andy's page only covers the later models, it will work on the earlier ones too.
Heaters are usually good, unless you a) have a big airlock or b) have had your heater hoses bypassed ? Switching the heater on to full and running the engine for 20 minutes should help the first, Changing your heter matrix and undoing the bypass (in that order) will sort the second
I am getting some heat out, it does take time and sometimes comes out of the dash ,but mostly in the foot wells,do the Z's blow out really hot heat?
Mine does, once it's engaged after a cold start, the car heats up very quick, good job in this bloody weather!
mine refuses to blow hot air in your face (when set ot max 40degrees, alhtough does do it at 35degrees??!?!?!), only at my feet or on the windscreen Im assuming its some crap to do with the fully automatic climate control, takes a little while to heat up properly but gets there eventually.
