Greddy Pfofec B 2 Boost Controller
I've got the Z back from the garage and they have done all the work also fitted the boost controller but they didn't set it up.
I started reading the manual yesterday and Damn that sounds complicated and sounds as if it could take a while to set up.
I want to set the Hi to 13psi and the lo to what ever you recommend so could somone please post what they have set each mode to so i can copy their set up.
Set
Boost
Gain
Start Boost
Warning
Limiter
for both hi and lo.
Also when i picked the car up it was badly miss firering also kept backing off then going could this of been the boost controller not set up or the ecu being reset and having to set it self back up again.
Cheers just printed them off i want to lower mine from 15psi to 13psi to play it save.
To do that what do i change.
When it was first fitted before setting up your not running any boost at all are you cos it felt dog slow compared to normal.
Also Any ideas why it was doing the backing off thing???
Sorry Kirbz for being a pain in the arse but the settings i took off the link above were set to 40% already but checked in the book and that is for the boost consistancy.
But the set mode is at 45% do you mean change this one to 40% rather than gain ????
