Found: Easy way to fix loose passenger window switch
Got fedup with people saying 'your window switch is loose'.
I bet I am not the only one that has a switch with the little plastic hooks broken off.
Fix:
Take a simple electrical double spade connector (See pic)
Drill out a small hole in the spade end.
Unscrew the existing screw behind the switch and fit the connector.(see pic)
Bend the connector at an angle and push it back in.
There is enough spring in the metal to secure it.
Job done.
Small screwdriver can prise it out again if necessary.
Not exactly rocket science but it works......will let you lot decide whether something this simple should go in the FAQ section... :) .
Martin
Martin
Got my vote! Simple ones are best! Nice one
yep my pass switch became loose i blame it on the misses
top tip though martin :cool:
sweet, i've got the same problem. It gets to me and i think must fix that, never have.Be looking at that tomorrow. cheers.
Nice one, one of the most useful facts I've heard for a while.....
Similiar too 'Wiping your arse with broken glass isnt a good idea'.....PMSL! :rofl:
This has got to be one of the most common problems.
Well done Martin, I will be using that technique myself.
thanks for that Martin. ive got the same problem. its amazing how something as little as a slightly loose passenger window console can spoil the whole of the interior!
Cheers Martin .. I have this problem as well. I will be using this to fix it up properly.
Good man. Top tip! :)
Same! Nice one mate :D
Good one, I know what i'll be doing in a hour or so! :D
So do we but what relevance does :xxx: have to this thread? :confused:
Balls!! Had the same problem with the passenger window switch. Went and bought a new surround at £stupid.99 :( :slap:
The surround has been loose on mine for years - will get around to fixing it one day ...........
