protoj ·
My Z is shaking itself to pieces slowly - time to sort the propshaft.
Can anybody confirm the part number of the "rear gearbox mount" I keep reading about?
The diagram I have in front of me has 3 likely bits: 11340, 11320 or (my favourite) 11375?
Also, has anybody recently got a one-piece prop? If so, where from? how much? any good?
Thanks.
