Can anyone help me,
I seem to remember reading that there is a test you can run on the intercooler system to check for leaks similar to the boost leak test idea, I dont know where I read it but it could have been on an old forum?
I have a compressor but need to know if it is ok to do and if so what the pressure it should be so not to blow the intercooler cores.
Any help appreciated,
a boost leak tester will pressurise the whole system & allow you to test the IC's, you only need about 5-6 psi
cheers Paul, any knowledge on whos selling them?
Thanks pete between you, youve saved me a couple of days messing around.
Buy you both a pint when I am next your way. (was there about seven years ago)
Seriously though thanks!
