battery upgrade question?
what is the best battery i can fit to me Z the bigger more powerfull the better, to fit current location. mine has just given up the ghost. fitting ice install at the moment. any help appreciated, come on tooley mate.
type number if possible eg 097. cheers "T"............
I was going to try an aux. batt in the boot for ICE, but I was worried that the alternator couldn't cope.
Any thoughts?
A second battery in the boot will not affect the alternator. You just have much larger reserves of power and will find the car starts quicker and the ICE can pull more current - reducing the light dimming effect (and therefor clipping) of big bass. Get a gel battery for the rear from an audio specialist if you can - often lighter with more power for the size. I had one that was the size of a standard family car battery but with 4 times the capacity of a double size lead acid thing. Have the added advantage of not leaking when split - if someone runs into the back of you or you have an accident do you want a bucket of acid on the back of the head? Make sure it's securely fastened down, has a serious earth and is correctly fused too. The power from a couple of batteries will weld/melt a hole through the chassis in seconds!
I had 2KW RMS of amps running from a Rover 220...
You can accidentally leave your lights on for longer too!
i dont really want to add another alt\battery setup, just upgrade the one in the car. i really need the type number of the battery as mine does not have one.
Hi there
I have just fitted a new battery 30 min ago'
I got one from Ford Rapid Fit...
£59 all inc. 3 years warranty
he one I ahve now is a bit more powerful then the od one...
550ma... the guy 80 amps more?...
as for the numebr you are after I'll have to look under the bonnet and now I can't sorry!
I was considering the optima... but I'm now sure it is worth the higher cost
got one today, sent it back + was on the wrong F##king side was an hella type 069 will try an 067 tomorrow as this should have it on the other side. DOH......cant complain it is not costing anything..he...he....
