Air Fuel Gauge help please fellas
I want to get a air/fuel gauge for my Zed. It says in the instructions that I have already that it should connect to the wiring harness with just one wire.
Can anyone tell me the O2 sensor wire to connect to from the harness?
Also .. as the Zed uses narrowband O2 sensors can I just replace the sensors to wideband ones?
I really wan't the gauge to work with a wideband sensor obviously.
All your help appreciated as always fellas.
OK .. search is my friend and I know where to place the wire in the harness.
But how do I get the gauge to work with a wideband sensor?
Well the kit with cable and sensor comes to ~£160 delivered but you have to build it yourself. Depends what you want to use it for really...
It is an excellent bit of kit. I will defo consider it in the future.
Using the narrowband sensors on the Zed with a air/ fuel gauge. Is it a complete waste of time? or will it give me a fairly accurate reading?
Well its no good for tuning purposes but it should give you an idea of when you're in trouble - which is really what cockpit guages are for. You're not exactly going to be racing down back country lanes wondering why you're 0.1 afr points off LOL
LMFAO .. No I wont be mate. I do have a AFC so I reckon that other bit of kit would be the mutts, especially to aid tuning.
Will probably get one soon then get the girl up to Thor or JD.
Chris
