Speed Delimiter on Ebay
Looks very similar to the one fitted to my GT-Four when it was imported. Certainly does the job so I don't see why not :)
Pah :slap: - contact John Dixon or Baggins. They will sort you out with a chip that will destrict the car the proper way. Plus it will allow you to run higher boost.... if you want ;)
.......but the speedo will still read incorrectly ;)
Running an N/A so boost is not an issue. What is "the proper way"??
There seems to be so many ways to sort out this KPH to MPH and delimiter business.
My head hurts and it's only 20:15!!! Another beer required.............
fit uk clocks then that way theres no delimiters that can mess up try the traders sec ;)
Cheers mate - will do that. The list of mods gets ever longer............
I've got a delimiter box for £15 if you want it.
Obviously, you'd still need to get UK clocks as the delimiter box wouldn't do the conversion to mph.
However, if you're getting it chipped, that should remove the limiter anyway. That's what I've done now, but I used the delimiter before that.
Dave,
I'll have the delimiter off you if Apache doesn't take it.
Let me know
Leonard
Sold to guinnal unless apache decides he wants it before the end of the day. :)
I'l pass on the delimiter thanx Dave - it's all yours Guinnal !!!!
