please help me
can you all have a look at the thread HOW FAST officer, and read my last thread, the problem is becoming torturous and i need help and advice
cheers
check pin no 53 on your ecu should be green/yellow IIRC! on mine it was held together by insulation tape :rolleyes: so worth a look could of came apart if someone has f***ed around with it,unlikely but worth a look
measure twice cut once ;)
diagram of ECU wireing... undo 4 bolts in passenger footwell remove bolts that hold ecu down carefully unscrew centre screw and separate wireing harness,check speed wire
greg
Have you done an ECU diagnostic to see if you get a speed sensor error?
Have you tried removing the convertor, if you have one?
it aint the speedo sensor, i got a barnd new one, but it think it could be the converter, as advised by all those i spoke too at TRAX, which rocked by the way. does anyone know where i can source one. i lost the name i think jonce gave me at trax
cheers
