Problem replacing injector connectors
I ordered some new injector connectors from Z1 and they are the correct shape but the wires are different.
On the connectors there are a thick and a thin wire but they are swapped over on the new connectors.
How are they wired?
Does it matter if I connect the thick to the thin one or should I cross them over so what might be a positive wire is going to the negative...
Chris.
its not gonna matter really.
thickness of the wire is there for currant draw, the same currant will be drawn down both the +ive & -ive cables, so dunno why they made 1 thinner anyway!
just solder them in the same way they go into the old connector (new thin to old thick IIRC)
Cheers, I was thinking that but just wasn't sure if current might run through the injector body to earth.
I presume they are just a connector for each end of a coil to move the valve.
yup, correct :)
You deserve an award for your excellent advice Paul ;) :rofl:
