Zorst fumes inside car
..especially when booting it.
Any idea's? Pretty sure exhaust isn't blowing but will get under and double check that.
Be from the manifold area if it is getting in the car James.
Did you put your O2 sensors back in ;).
Is it coming through the Air vents or transmission area ?
Jeff did my O2 sensors some time ago. It seems to creep into the car if my window is open - under heavy acceleration esp.
have a look and see if they are in tight they can wobble lose
Call me stupid......surely if it only happens when the window's open it's coming through window??
Mine does that too, not much , praps when there's a strong wind blowing up your arse,
what am I on lol
I've got the same prob too! any one know what the two pipes about 15mm diameter that conect to both exhausts do? because Ive got uprated down pipes there was no conector for these pipes so was wondering if exhaust fumes came from there??????
Ive heard cases on cars where the rear boot seal it knackered, a long shot but might be woth checking.
You ever driven with the rear hatch open the exaust fumes kida get swirled into the car due to aero dynamics and all that!!
Reckon you're right there scoops, opening window then draws it in.
Well my rear hatch is squeeking like a mother fooker at the moment, so you could be onto something! I will check all suggestions and see how I get on. There is definately some funky aero dynamics going on somewhere for it to be drawn in....hmmm, I'm thinking possibly my boot cover-blind thing might not have been in place due to a full boot, might have to investigate that one too. Cheers.
These are for your AIV's. You may as well remove all of this form both under the car and the inner wings. Then disconnect them from the solenoid.
They are no use to you anymoreb ;)
Sounds good to me less weight :)
