Help please
Hiya people,
Right zed is running fine, but it feels slow. Boost takes a little while to reach full stock boost. and dont really pull that hard. any ideas what to check?
cheers, will have a look later, is there any places i should check for a leak?
Intercoolers, coupling pipe between comperssor inlet and hard pipe, 4 main boost hoses.
Have you checked your foot is fully on the accelerator? :D :D
LOL, no I did'nt have to try that a little later :hyper: :slap:
Actually that's a fair point, check you're actually making full throttle when you've got the pedal down. Seen it before.
Could be a fooked / slack cable I guess. Check under the rocker cover
I found that my throttle cable was connected to the wrong cam/pulley thing which gave similar symptoms.
Matt I'll bring a boost leak detector and compressor with me on Saturday. Are you coming over in your Z?
If it had a boost leak it wouldnt reach max surely?
All the cars i've had that have had boost leaks small or big have just stopped a few psi or more short of the right level dependant on the size if it?
Cheers Stu that would be superb :D any chance of a conzult too? :slap:
Mathew (Pushing his luck)
Unfortunately mate, my ConZult is broken :cry:.
I'll bring it along with me as we may be able to fix it but I'm waiting to hear back form danny about some sort of warrently I may or may not have with it.
I've seen you drive Matty, it's your vertical right foot! It want's to be horizontal :D
