- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Since cleaning the throttle bodies about 6
weeks ago i have a problem with idle anything
between 1500 and 2000 rpm the hotter the engine the higher the revs.
Yes, did do the negative earth thing for more than 30 mins and must have done some 1200 miles since so ECU should have learnt by
now.
To date have done the following:
Cleaned temp sensor connectors, these were shite and this has made a difference now idling at 1100 rpm without air con / fan running, temp sensor is working as revs rise
if lead is removed.
Cleaned throttle position sensor connectors.
Cleaned MAS sensor connectors.
I now want to adjust the idle but i am fu*ked
if i can find the idle screw, where is it
located in the engine bay?
have read the stuff on TT Net etc but this dosent indicate where the IAA unit actually is! where is it?
Also would appreciate any further suggestions on what can be done?
Cheerz chapz
Ian
