Help! What's This???
BEEN FITTING THE OIL COOLER KIT TONIGHT,AND CAME ACROSS A UNIT STUCK BEHIND THE BUMPER REINFORCER[WHEN I SAY STUCK I MEAN MORE CRAMMED]ON THE PASSENGER SIDE.MADE OF PLASTIC AND MOUNTED ON A METAL BRACKET,THE CASING RESEMBLES A HORN[sPIRAL SHAPED]AND IT'S GOT FOUR WIRES INTO IT THAT SEEMS TO PLUG INTO THE SIDE/FOG ASSY-ALTHOUGH IT WASN'T CONNECTED :rolleyes:
WHEN I DID CONNECT IT UP-USING THE PLUG ON THE WIRES WHICH LOOKS FACTORY,THE FUSE BLEW FOR THE SIDELIGHTS-ANY IDEAS,IS IT IMPORTANT
CHEERS GUYS :)
The 300zx has dual horns.
put it back how it was and change the fuse and you should be ok ;)
THANX SMW1-BUT THE HORNS ARE BOLTED LOWER DOWN-SAID IT LOOKED LIKE A HORN BUT IT MOST DEFINATELY AINT!!
GONNA TRY AND GET A PIC UP THAT MIGHT HELP? ;)
Could Be?do The Zeds Come With A Factory Alarm Option??
if it dont work take it off and save soem weight. you could alway clean it and sell it on ebay lol
