Help!
Just driving back from footy, had adjusted the boost contoller again a bit to see if I could tweak response a bit. My car was running fine, although boost was dropping off a bit due to the new settings, but I haven't gone over board on settings I don't think. Didn't touch the unit again, but hitting boost again a few miles up the road, car felt a bit slower.
Slowed down and it flelt like it was running rough suddenly. At low speed the idle is not too lumpy but the car feels like it's running on 5 cylinders. It souns very rough and the engine is shaking a bit when you rev it.
There is no smoke, can't see any pipes off at least at the top of the engine.
What should I look for?
What checks can I do?
Mine did this randomly one evening too, and wiggling each injector connector showed it to be a corroded wire to the connector, causing one cylinder to misfire.
Got some from AndyZ and soldered one on and all was well. Could be the same with yours? Or a coil pack connector.
Good luck
Pete
and check the coilpack connections :)
Vijay
Cheers chaps.
Wiggling the wires seems to have cured it again, :hyper: although I couldn't tell which one it was :confused:
Will keep an eye on it I suppose.
Thanks.
Alex.
