Heater matrix bypass
anyone know what size diameter and length of hose to get to do this, my guess is about a 12inch peice should do it with out kinking, but thought id ask i as know some of you have done this,
cheers rob
you can use one of the original hose and just bend it over, it doesnt matter if it kinks as it is a branch of the main water system, you wont block the flow. HTH.
well no joy, i tried both pipes and it seems the matrix ends are a smidgen smaller so couldnt get them on the block outlets, ne mind ill pop down the autofactors and take the pipe, that way i cant go wrong, suprisingly the car car started 1st turn of the key, not been turned over for about 4 weeks, no missing or spluttering, just need to get it back drivable so i can get it down the body shop
