Switches on clutch pedal?
Converted from auto to manual and i've got 2 switches on the clutch pedal that aren't connected to anything.
I know one is a cruise control cut switch but not sure what the other is.
Should these be connected to anything?
Think the other is used by the power steering - prolly goes to the ecu...
I don't have any plugs spare on the harness but I presume the cruise still works on the brake pedal?
On a manual does the cruise have 2 cut switches for brake and clutch? Must do I suppose.
Cruise does indeed have a clutch switch on the manual - if you don't have the switch, then be VERY carefull you don't dip the clutch with cruise engaged or you will be back off the road for another 18 months LOL
:eek: I was thinking of removing cruise anyway TBH.
Seems a waste of time on a manual and I've never used it.
If the switch contacts are closed when the pedal is pressed then I should be able to join the 2 switches together to do the job properly.
So whats the point of that and is there an equivalent on an auto?
