Prefec B Settings
Hi Peeps
Can someone who has a profec B please list their settings so i can put them in mine.
I would mess with it myself but as i'm still running in i dont want to be blasting up and down the road changing the settings but i would like a little extra boost at lower revs....cant be getting beat by those XR3's can i now :xxx:
Many thanx
Mike
Hi Mike,
I am in the middle of setting up mine aswell, best to give John Dixon a call as he is helping me with mine.
Good luck mate
Rich
P.S. NO burnouts..... :)
Mike,
What turbos are you running?
For stock, try
Gain = ~25
Set = ~35 and work up (35 should be around stock) ~45 usually gives 15psi
Start boost ~3psi less than peak. Leave this at 0 until you've got stable boost
Limiter at 16psi with 20% cut.
If the tubs are bigger, gain will likely need to be higher, setpoint lower.
Dont worry rich i wont yet just in case give it another 850 miles then i'm away!!
Theres a new yellow lambo near me so cant wait till i can redline the bitch and frighten him in it :)
Kirbz
Mine was Ok when setting up with John's help, then went way out again after I started playing too much!
Got mine sorted a little better yesterday, will have a look tomorrow for you and post as well, can't hurt to have a few.
I do notice that things get a bit peaky if the car is cooler, say the first time you boot it after 10 or so mins of gentle driving off boost. Then as the car gets hot, things settle.
