speed restrictor
where i can get this puppy removed off my import and what's involved in the removal?
either do a search!
its not about removal,its what you add ie.. little blackbox available at the z centre delimiter/converter and replace dials for MPH if you want!
or fit uk clocks,as ive got a chip?the needle goes all the way round the clock but doesent slow the clocks down obviously :)
If you fit a speedo converter it will be set to 112 * 8/5 whatever that works out to. These have disadvantages in as much as the steering gets over light.
If you want to remove it completely, you need to change the chip.
As Greg says, UK clocks + chip is the way to go.
Drop me a line if you want a chip.
