TPS adjustment
Have just tried the TPS adjustment. Put the paperclip in the middle wire on the connector on the side and got 0.0125 volts. Put it in the middle wire on the one that comes out the bottom and got 9.52v from the plug!
Am I doing it wrong - please advise.
P.s. could someine write up an FAQ on this?
Ivan
It's between white and black on the plug that's seperate from the TPS body itself - NOT the one that comes out of the bottom of it. Or just white and earth of course.
And you must leave the connectors plugged in - hence the need for a paperclip to shove down the back of it.
If it still doesn't work you're not pushing the paperclip in far enough, or your TPS is knackered LOL.
There is a write-up somewhere out there... try http://www.300zx.org.uk.
