How much boost?
How much boost can I run with T28's, 555's and big coolers with stock internals?
Am I right in thinking that these turbos will be pushing far more air through for the same pressure so the usual maximum of about 16psi would actually be too much?
If so, how do I gauge how much is too much for my engine?
Chris.
  • Replies 40
  • Views 1.6k
it this gonna make much difference?? surely the amount of max boost you can run is going to be limited by the compressor housing/wheel, not what bearing you have. :confused: ok its gonna help with spool up, but would it make that much difference to boost?
After talking the head honcho at Turbo developments, he said that 270 thrust bearing can run 15ish max,360 18ish max and BB can just run as high as you can. This is talking about the limits of the turbo for longevity, not the engine's limits or the amount of psi the turbo can develop!
555's fit straight in speedy
Mark BB turbos will NOT take high boost levels ask Nico the Z guru:D;)
Well I suppose it all depends what you mean by high!
I think the guy was saying, your engine will start detting before you reach the limits of your turbos with BB!
Turbo Dinamics Roller bearing turbo, high flow 60 trim compressor wheel, CNC re-Profiled compressor housing, T25 left hand thread turbine wheel assembly, staggered gap / total seal turbine end piston ring fitted, 0.64 A/R turbine housing, up rated actuator.
Thats what me got, all be it sat on the floor of the garage at the mo. I will also be having Dump Turbo Headers, larger Braided oil feeds etc..
Rossy - please note that unless TD have changed again they supply the stage 2-3 with standard actuators - if you want the uprated 14psi ones you have to ask specially.
Regards,
alex
I would have thought each turbo's A/R map would be more of a limit than the bearings!
Nicocrocopig said the bearings are so small they :eek: self distruct when you run serious boost through them.
To be truthful all of my knowledge around turbos comes second hand and it would be nice for an "expert", to clarify all of these areas!!
To me it all seems to be a black art!!
Maybe we should get someone to write up a way to decipher these things, like a/r
ratios, compressor and turbine wheel sizes, charts!
LOL!! i think some of it is down to black art!! :D
trouble is, sometimes what looks good on paper wont perform in the real world. its down to people that actually buy the turbos, fit other aftermarket parts & test them to find out what works best.
the proof of the pudding is in the eating - and all that :D
we need to build up a big database of dynos - it's the only way to compare them. just like bernie did at ooparts
we should be able to get a comparrison for
stock
TD stge 1
TD stage 2-3
PE1420
SE T28
SE t5/28 hybrid
greddy TD05-16G 6cm
greddy TD05-18G 8cm
just off the top of my head - what other turbos are we running in the UK? anyone running JWT's or HKS 2530
that would give us a nice cross section
Regards,
alex
p.s. we could get PeterR to give a masterclass at billing :D there isnt much he doesnt know.
Regards,
alex
Regards,
alex
That is in the agenda for Billing already :dance:
i know ;)
Are we allowed to put our hands up and ask teacher questions? :slap:
Quite a few peeps on the forum are running JWT Sport 5oo turbos. I think Jock is for starters ???
No now shut up, put the D hat back on and sit in the corner :p
Will make a annoucement in the next couple of days about things we have planned for Billing! :hyper:
