back shocks
looks like i need 2 back shocks 91 tt manual uk it is totally original i think i want to keep it that way i got a price over here of 568euro supply only for two nissan part no.5621037p25 are they much cheaper over there or is there a good other option thanks guys in advance trish
The UK ones I bought were just over £100 each with some discounts from Nissan. They are Tokico and have the hollow piston rod for the normal / hard actuators. The other option is the stock import spec ones that go for less than £40 each and disconnect your actuators. The import spec ones are non adjustable. There are also various after market types as well.
I think the import ones are softer, and if this is the case they won't match the spring rates and the ride and handling will be all over the place. Also the fronts will still be harder UK spec, again destroying the handling.
Uk ones will be the same softness in normal every day running. Its only when you pull the handbrake up a notch that it invokes the hard ride through the actuator, so nine times outta ten the ride will be the same.
I have import shocks on my UK car, cos they are a damn site cheaper. Would put some nice Tokiko ajustables or some Konis on there next time, if I have the money!
Nick
:cool:
I pretend to work, they pretend to pay me!
