billing maybe just maybe
got back from SE today and maybe (slim chance) i might make billing
if i get there this will hopefully be the spec
candy apple red paintwork : bomex front (modified for larger intercooler vents, indicators removed and intercooler rear vents inserted) : venom front lights : side repeaters removed : M3 type wing mirrors with integral indicators : veilside C1 side skirts (modified for wide arch) : strosek wide arch : wings west rear (modified for wide arch and single exit exhaust) : custom rear light conversion : spoiler removed : tailskin : custom rear lip : doors de lined : custom bonnet vents : SE bonnet bulge : SE headlamp panel : quarter panels tinted with gold reflective : candy apple painted throttle cover and timing belt cover : lowered blitz springs : Koni shocks : front & rear strut braces : groved & vented rear disks with porterfield carbon kevlar pads : R33 brembo front brake conversion with 4 piston callipers : 328mm x 32mm disks with porterfield carbon kevlar pads : master cylinder brace : 18” league alloys : forged pistons : forged H beam con rods : heads skimmed, gas flowed and ported : group N head gasket : head mig wired : solid lifter conversion : re-profiled cam : vernier cam pulleys : aluminium lower drive pulley : dual POP – twin MAF intake : 60mm throttles : pentroof TD 05-16G turbos in 6cm2 housings : HKS racing 50mm wastegates : pentroof manifolds : polished upper plenum : gas flowed, ported and matched upper and lower plenum : HKS intercoolers : custom aluminium radiator : stainless radiator pipes : fidanza aluminium flywheel : organic racing clutch : nismo 555 injectors : SE downpipes : decatted test pipes : HKS superdragger exhaust (single exit) : blitz dump valves on stainless pipes : performance stainless intake pipes : nismo radiator cap : pentroof oil cap : chromed engine parts (break reservoir cover, clutch reservoir cover, HICAS cover, oil dipstick, battery tie down) : stainless engine parts ( brake servo cover, centre slam panel, headlight covers, fuse cover, centre throttle strip) : metal braided fuel hoses : coloured air/vacuum hoses : performance earth grounding kit : greddy profec e-01 : greddy emanage : blitz turbo timer : racelogic traction control : A pillar two guage pod with blitz boost and water temp : DIN 3 gauge pod with afr, oil temp, oil pressure) : mines clocks ( 200 mph speedo and rpm) : chromed clocks rings : candy apple painted central panel and door switch housing : leather cobra racing seats : black leather trim : momo gear shift :
keep your fingers crossed
Regards,
alex
Nice one bud, look forward to seeing it in the flesh. Sounds awesome!
hope you get her back in time must admit you can't get a better colour
you dont think its a bit effeminate? :rolleyes: :dance: :tongue:
:dance: :hyper: :dance: :hyper: :dance: :hyper: :duffer:
?1345856
?1345873
edit:bugger what happened there - ****ing technology :rolleyes:
fecking class, after a real sh1t week that made me smile
Russ seen the latest message from Peter?
ah *****x :cry:
russ - you still not going
if mine is ready it would be class to get them together :dance:
Regards,
alex
my car is going if im not , but we should both be there . are you there both days ?. if your car is not ready are you still going ?
not sure to either at the moment - i wont stay over so i will probbaly only be there on the saturday
Regards,
alex
Regards,
alex
if were both there on saturday fancy a :duffer:
if you car is not ready do you want a lift , but it will have to be in a 406 or lexus
sounds great m8 - wouldnt that just be fine - both of us turn up without the zeds - are SE taking yours?
Regards,
alex
yes se should be taking my zed up so i will be going up seperate . bloody ironic both of us no zeds
Glad to see your car might be done alex about time things started to go your way!! no doubt i will see you at billing either with zeds or not!!
Mike
