set-up advise!
hey guys,
not been on hear for a while, how is everyone?
at last after nearly 3 months my zed is ready to fire up again! im now after some info on what psi i should be running and tech advise on how to set up AVCR controller!
can you guys please help!!!!!
right where do i sttart, this is my current setup:
blitz sus induction
Greddy twin intercoolers
t25/t28 smithy hybrid tubs
twin-divorse tub down pipes
AVCR boost controller
inter-changable de-cat pipes (staight or silenced)
scorpion rear silencers
mines ECU
standard fuel injectors
uprated oil and trans coolers
auto g-box ( 93 model)
C2 gauges
i think thats about it!
will this mines ecu give enough fueling for this set_up??
worried about melting it!
sorry its long winded
any help gratfully recieved!!!!!
steve :dance:
Amazed no-one has replied yet...
You'll be more than safe running 1 bar... and frankly more than 1 bar on the public road and you'll kill yerself! (You could always use the B-map for Santa Pod and so on...)
Setting the AVC up is a nightmare - self-learning mode doesn't work properly on twin turbos like ours so you have to set up the duty cycles yourself.
Basically, you guess a duty cycle that's going to give you the boost you want - you blat it up to a ton and back - and then you have a look at your peak and troughs and diddle things accordingly. If you find you've got boost wobble or mega spikes turn the feedback speed down a bit. From memory 68% or so gave me 1 bar, but I think I had vac leaks now I know more about it. (That car is long gone!)
You can also set up the boost per gear or per rev increment - which is good because I found 1st gear at 1bar just span the wheels once you hit torque no matter how careful you were with the throttle. I had the A settings for town so boost was mild until about 4000 revs - so I'd never get caught out on roundabouts or what have you - it wouldn't take off unless I really meant it.
B I had pretty flat. :D
I'd book yourself into Thor or similar and get the pros to do it. (I'll be doing that when I get a controller onto mine...)
Did you turn up at a meet at exeter services last sunday ? Think i saw your their - in a red Zed.
I was up their with the ultimate jap car club - or am i totally wrong
I would be tempted to go Thor or simialar to measure your Air/Fuel curve as the injectors start to struggle above 1bar with stock turbo's. If your tubs are much bigger there will be a lot more air at 1 bar so you could run lean at 1bar...
sorry chopper your completely wrong!
mines black for a start,
will be there soon though!!!
:tongue:
hey zevans thanks for all the help,
at least some ones willing to give their opinion!!!
nice one mate :bow: :dance:
Sorry mate - someone had a red one their with 300zx.co.uk written on it. And no one ever replies in the "Was it you" section !
Ignorant - thats what i say !
cheers
cheers
has any one else got any input on the set=up please
just trying to get a few opinions!!!!
for reference, I'm using 47% duty to hit 1 bar. (when i first set it up i used 62% duty to hit 1 bar, but I've since a few things and tidied the vacuum hoses up)
I've also turned the boost down for 1st gear approx 12 psi to avoid losing traction, and turned it down a little for fifth as it was overshooting a bit due to the extra load.
the injectors are going to be the bottleneck in your setup, get bigger injectors!!
is 15psi suitable for stage 2/3 tubs stock injectors and mines ecu!
want to play on the safe side!!!!!
