June 3, 200421 yr Hi all, now I have anew Zed. But this time its an Import, few thing that Are different: (1) When I put the car in reverse (auto), it makes a beeb, beeb sound. But only when I select reverse is this normal? (2) When I put my foot on the brake padel a Red 'Lights' on the dash lights up. But the brake lights work. (3) What does the 'Power' button do? As my old auto UK did not have it. cheers for the help, Alastair.
June 3, 200421 yr Hi all, now I have anew Zed. But this time its an Import, few thing that Are different: (1) When I put the car in reverse (auto), it makes a beeb, beeb sound. But only when I select reverse is this normal? (2) When I put my foot on the brake padel a Red 'Lights' on the dash lights up. But the brake lights work. (3) What does the 'Power' button do? As my old auto UK did not have it. cheers for the help, Alastair. 1 Yes this is normal and you will also have a beep when you go over 110 Kmh (http://www.aus300zxclub.com/tech/Alarm.htm) 2 This will just be a loose bulb probably in the spoiler brake light. Mine does this and just have not got round to fixing it. 3 Power button (Do a search) ;)
June 3, 200421 yr Hi all, now I have anew Zed. But this time its an Import, few thing that Are different: (1) When I put the car in reverse (auto), it makes a beeb, beeb sound. But only when I select reverse is this normal? Yes (2) When I put my foot on the brake padel a Red 'Lights' on the dash lights up. But the brake lights work. That generally means that one of the brake lights is out. Check all the small bulbs in the light on the spoiler. If that's not it, it could be that a previous owner has rewired the lights to use one of the brake lights as a fog light. (3) What does the 'Power' button do? As my old auto UK did not have it. It's the equivalent of a sport mode. It holds the gearbox in a lower gear than it otherwise would
