In Need OF Pipe Help!!
Can anyone tell me the part number of this bit of pipe (scuse the not very clear pic but it's the best I could, only one I could find TBH!!)
I need one sooner rather than later!!
Cheers,
Matty.
i got a parts catalog. ill see if i can locate it for ya. if anyone else gets in there 1st though.
bloody nissan parts cat is a bugger to use
That might be a heater matrix pipe - are there 2 of them criss crossing over each other - attatching to a metal pipe at the top and going into the bulkhead below? If so the part numbers have been mentioned on here a few times.....
I think they are -
92400-30P00 inlet
92410-30P00 outlet
try a search on these part numbers for further verification
Does it come off the air regulator and on to the back of the balance bar?
If so:
14099-30P02 hose-air
the s shape hose at the side of the air regulator near the battery
is 14099-30p01 - hose Vacuum
the otherside of the air regulator is a larger s shape
and is as andy said
hope it helps
Thanks fella's!!
:D
Usual beverage in the post........;)
Matty.
