:bow: Has anyone replaced ther injector leads, just got a set from states,
how hard is it
got mine to do still, its just a case of cutting the old plugs off, then soldering the new ones onto the existing wires
must get round to doing mine. might do it tomorrow if im not too busy :cool:
engine plays up if i wiggle the wires, think thats why i'm getting code 34 on ecu,
sunny tomorrow might get the wire cutters out lol
code 34 is det sensor/wiring
yeah i buzzed out the det sensor seems ok, low boost about 8psi max, still redlines
running optimax, had the car about 4 months
car just seems lacking in power, de cat job been done, no smoke,
want to chip it but need this sorted first
I've done injector connectors and coil pack connectors.
If I could give you a tip it would be to not only replace the connector but also trace the wire back and cut as far back as possible (obviously not too far back that the new one won't reach lol). The wire is usually corroded a good few inched back from the connector itself. It was with mine anyway.
Spot on Stu,
Replaced all mine about a year ago , but had to replace all the injector connectors and a good few coil pack connectors on a car last week and the wires were green and crappy a good 3 inches up from the connectors themselves
just finnished, took em back to the main loom, runs a treat now, cheers chaps
How much are these from nissan or is there someone in the UK that stock them? mine are in a right state.:(
