FAO 51x
Simon.do you have any pictures of your tubs fitted to your engine?
I want to see the pipe that goes around the engine mount.
Hello? :p No, sorry mate, I haven't. It all got bolted on and jammed in the bay before I had a chance to. I know this might sound a bit unusual, but it's true. I've seen the pipe in question tho. It's got a bit of a restriction in it, but what you gonna do, huh? It's possible Stu's got a pic from the SE open day(?!). I could drop in and see if they're building any other engines with T28's if you like.
Ok mate NP,What am I gona do? you tell me LMAO:(
Oh f*ck! Errrm... !?! Custom engine mount?! What did Pete do for Andy E's? It's not like you can even bolt in some kind of spacer to re-angle the turbo, is it? Fit smaller turbos? ;) Hmmm.
I have another Peter sorting this in Europe;)
Cool. It'll be interesting to see what he does. I dunno. Maybe an engine mount that wraps around the intake pipe (top and bottom)?
Simon the problem is the air intake on the 18g,It is 80mm the 16G is only 50mm (stock size)
They cut a piece of there to fit. Check the pics of the guys in the US that have the td-06
not true - the standard 16g housing is now the 8cm housing. Certainly the greddy kit comes with the 8cm housing. Which is unfortunate because the housing is too big - Trust standardised the range and stuffed all the wheels 16g 18g and 20g into the 8cm housing. you can even get the big turbos like the T67-25G in the 8cm housing.
Spool up on the 16g is enhanced with the higher back pressures that the 6cm housing gan give with no loss on the top end.
The only 6cm housing for the 16g is the pentroof turbo - oh and mine :cool:
ok so i'm a nerd :shock: :tongue:
Regards,
alex
wohoo T88H-34D in a 22cm housing
DOH!
edit: mother hubbard - that turbo is rated at 980ps for 1 turbo
DOH!
Finished now?:D
Alex don't let Bob brainwash you with *****cks:D My supplier says I am right :tongue:
Finished now?:D
you misunderstand me - that is a trust turbo none of this garrett nonsense ;)
first three figures after the description is the power rating
i.e.
TD05H 16G 360 ps
TD05SH 16G 400ps
Trust (MHI)
T517Z 3807 N 50 48.3 68 ? ? ? 8, 10 cm2 N3 Y Int T25
T518Z 4207 N 55 50.6 68 ? ? ? 8, 10 cm2 N3 Y Int T25
TD05H-14B 3005 N 55 43 58 76 55.9 49 8 cm2 Y N4 Int/Ex TD05/06
TD05H-16G 3605 N 50 48.1 68 76 55.9 49 6, 8 cm2 N4 N4 Int/Ex TD05/06
TD05SH-18G 4005 N 55 50.6 68 ? ? ? 6, 8 cm2 N4 N4 Int/Ex TD05/06
TD06S-20G 3707 N 60 52.6 68 ? ? ? 8, 10, 12 cm2 N4 N4 Ex TD05/06
TD06SH-20G 4007 N 60 52.6 68 ? ? ? 8, 10, 14, 16 cm2 N4 N4 Int/Ex TD05/06
TD06SH L2-20G 4307 N 60 52.6 68 ? ? ? 6, 8 cm2 N4 Y Ex TD05/06
TD06SH-25G 4507 N ? ? ? ? ? ? 8, 10, 16 cm2 N4 Y Ex TD05/06
T67-25G 5507 N ? ? ? ? ? ? 8, 10cm2 N4 Y Ex TD05/06
TD07S-25G 6507 N ? ? ? ? ? ? 14, 17, 21 cm2 N N4 Ex TD07
T78-29D 6907 N ? ? ? ? ? ? 14, 17 cm2 N Y Ex TD07
T78-33D 7507 N ? ? ? ? ? ? 14, 17, 24 cm2 N Y Ex TD07
T88-33D 8207 N ? ? ? ? ? ? 15, 18 cm2 N Y Ex TD07
T88-34D 8507 N ? ? ? ? ? ? 15, 18, 22 cm2 N Y Ex TD07
T88H-34D 9807 N ? ? ? ? ? ? 18, 22 cm2 N Y Ex TD07
you might be interested in this
Nissan S14 GarrettT28 300ps 5 N 60 46.6 60.1 62 53.8 41.7 0.64 N Y Int T25
Alex can you just give me the site where you got all this? 5 N 60 46.6 60.1 62 53.8 41.7 0.64 N Y Int T25
The way it is pasted has come across all mumbo jumbo :rolleyes:
secret - my find :tongue:
Right Alex,you this may interest you too..........................
T28xSmallH=boom....Don't mess with housings bang clankn490n67n874 41.7 0.64..
:D;)
Alex................................................
7 - Source: RevSpeed Magazine #2 2002 :rolleyes: You would get more accurate information from Halfords:D;)
:D;)
MWAHAHAHA
so true :bow:
edit i think you mean the bang clankn smokin490n67n874 41.7
2nd edit - Ian you're a genius
a bit weird but a genius
Regards,
alex
Regards,
alex
Thank's Alex :dance:
