code 34 - what now
look here - it describes how to test & bypass (NOT RECOMMENDED!!) the det sensor. if the det sensor is faulty then obviously it really requires replacing (mind you - as youve got a boost controller youve got no "safety boost" anyway. & i believe some chips do away with the safer ignition timing knock maps too)
will it be the sensor failing or just a warning of detting
needs a service
hoping it will cure it
should i just bypass it for now
i can't afford an engine out job
2 weeks into Zed ownership
I read somewhere (yes i can read)
that a code 34 causes safety mode
my Zed still goes up to 6500 if you dont floor it with full boost
when you do floor it, it wont rev over 5000
you have to turn off then restart and 6500 again
so what could be wrong
try cleaning plugs to det mate
it fixed mine for the price of 2.99 electric cleaner
steve
