FYI: injector/sensor connectors
Was just sent this to my website address :-
I have recently changed the injector connectors on my 90na z
also the temp sensor(ecu) and connector and the 2 connectors for the air (I think) sensors either side of engine (not the lambda)
They were corroded, nissan told me the usual £600 wiring loom bullshit!
However I located some connectors that fit, if you cut the locator off the sensor/injector or cut a grove in connector.
They are from Durite (+44(0)1255 555200 http://www.durite.co.uk)
part number : 0-012-71 (juniour jack 2 way connector) £3.02+vat each!!!
Hope this could be of help to many z owners
Simon
Looks like it's worth further investigation.
Its a pitty their site is probably one of the worse I have ever seen.:mad:
